Handlepole, Steering, Throttle, Grips- ADA, RRP, Cold Fusion, Thrust, ODI
JetManiac
Stoked
orlando
Steering Systems from RRP, Cold Fusion, ADA, Thrust, and Blowsion
RRP
RRP ninja OVP lightweight fatbar steering system 289.
RRP billet pole steering stop/chinpad support 65.80
RRP steering system for std 7/8” bars 245.
RRP AST rubber bump pad 64.95
(Specify original or OVP steering, original pad will fit Cold Fusion FB steering also)
RRP steering rebuild kit (2 bearings, 4 washers, 3 Orings) 29.95
RRP steering replacement O-ring kit 12.
Thrust
Thrustone OVP fat bar steering system $279.
Thrustone Shorty fat bar steering system $279.
Thrustone Combo fat bar steering system $324.
(includes clamps to run either as OVP or shorty setup)
Thrust steering rebuild kit for all Thrust steering systems 39.95
(2 sealed bearings and 2 bearing cups)
Thrust billet steering stop/chinpad support 54.95
ADA Racing
index.php
ADA NEW sealed bearing steering system 139.95
index.php
ADA
billet standard 7/8 bar steering turnplate 69.
ADA billet Fat Bar steering turnplate 99. (silver or black)
-for ADA, UMI or UMI style (blowsion, wamiltons, etc.) bearing steering systems.
Steering cable mount can be mounted on either side of the plate. Can also be used on Kawasaki SXR by relocating the pivot post in stock subplate to forward hole.
An easy, inexpensive way to switch to 1-1/8" Fat Bars from RRP or Blowsion. Replaces turnplates on UMI style steering systems.
Cold Fusion
Cold Fusion steering systems use stock SuperJet steering bushings, large locking pro nut included.
Cold Fusion pro series fat bars turnplare steering system 179.80
Cold Fusion pro series 7/8" std bars turnplate steering system 129.80
Cold Fusion steering locknut 34. (Inc. with Pro series)
OEM SuperJet steering bushing 17.95/ea.
Blowsion
Blowsion
OVP universal Fatbar steering system 261.90
The all new Universal OVP "Over the Pivot" Sealed Bearing Steering System. Fits all OEM Yamaha and Aftermarket Handlepoles. Chinpad will need to be modded for clearance.
Blowsion Kommand shorty turnplate 59.95
XScream
XScream
Adjustable Steering System 179.
XScream steering rebuild kit 29.90
Handlebars
Blowsion Blaster/Sport class bars 69.95
Aura Fat 50mm riser bars 68.50
RRP Fat 50mm riser bars 69.90
RRP Fat 4 degree bars 64.90
Aura Fat straight bars 59.95
RRP Fat straight bars 59.95
RRP std 7/8" straight bars 49.90
ADA zero degree 7/8” straight bars with crossbar and pad 65.90
ADA 4 degree 7/8” straight bars with crossbar and pad 65.90
Billet 7/8" bar clamp set (threaded with tapered head stainless bolts) for UMI, Blowsion, etc. turnplates 22.95
ADA crossbar pad 12.95
Hot Products longer crossbar pad
RRP handlebar extensions 39.95/pair
Steering rebuild kits
Steering rebuild kit for UMI steering 29.95
Also for UMI style steering systems like Blowsion and Wamiltons
(New orings, sealed bearing, and needle bearing or teflon replacement kit)
Koyo Steering rebuild kit for UMI steering 34.95
(upgraded kit with Koyo sealed bearing)
Locking stainless collar for UMI, Blowsion, or Wamiltons steering 32.90
(replaces crappy nylock nuts that always come loose)
RRP Fatbar steering rebuild kit 29.
RRP std 7/8" bar steering rebuild kit 29.
Xmetal adj steering rebuild kit for 29.
Steering rebuild kit for Blowsion OVP steering 29.
(specify for Blowsion pole or universal model)
Steering rebuild kit for ADA steering 29.
NEW design UMI Racing billet steering system for WaveBlasters $549.80
* 1" taller steering head height
* Steering head now works with standard (7/8") or fat bars (1 1/8") and includes extra top plate and adapter.
* Steering is now anodized in Black.
* Steering arm is longer with more quick steering adjustment.
* Fits 1993-1996 Yamaha WaveBlaster 1
UMI Racing billet steering system for Kawi X2
UMI Racing B1/X2 steering system rebuild kit 29.95
Throttle Levers
PJS Billet Throttle lever 79.89
UMI billet throttle lever 81.90
Black or silver, straight or angled
RRP billet throttle lever 84.95
TBM Billet throttle lever bushing 99.90
TBM Billet throttle lever bearing 109.90
Thrust finger throttle lever 84.95
HSI billet throttle lever 85.49
OEM Yamaha throttle levers -clean, used 28.
Cast aluminum throttle lever 34.90
Throttle lever to cable adapters:
Most a/m throttles to Yamaha 6mm cable 12.90
Most a/m throttles to late model 8mm Kawi 14.90
vvv More Below vvv
JetManiac
Stoked
orlando
ODI Lock-On Grips
ODI grips feature ODI patented Lock-On technology which provides easy installation and 100% slip-free performance. Include Snap Cap End Plugs.
ODI Rogue Lock-On Grips $33./pr sale 29.80/pr
Rogues are perfect for those who prefer a larger grip. Large raised pads and knurled surface texture offer improved traction and deep grooves which channel water away from your hands. Black or lime green.
ODI Ruffian MX Grips $33./pr sale 29.80/pair
MX grips offer the narrow diamondized pattern that made ODI Ruffian grips a classic, with an added half-waffle pattern for additional traction.
ODI Ruffian Grips $33./pr sale 29.80/pair (black, blue, green)
ODI Troy Lee Grips -black, white, red, orange, yellow, pink, teal $33./pr sale 29.80/pr
ODI X-treme Grips $33./pr sale 29.80/pr (black or charcoal grey)
ODI VANS grips (black, red, or natural gum) $33./pr sale 29.80/pr
Featuring the classic Vans ® waffle sole pattern and constructed from ODI's proprietary grip compounds for a consistent feel that provides exceptional control in all conditions.
Handlepoles and Parts
Pole Bolts
Handlepole pivot bolts
Pole pivot bolts
fit all RN Superjets 1996-2020, FX-1 1994-1995, and are used for most a/m standup poles and hull builds.
Yamaha RN Super Jet 96-20 OEM stainless handlepole bolt $92.99 sale 81.89
(bolt only)
Stainless jam nut and washer for pole bolt 3.95
Yamaha RN Super Jet 96-20 a/m stainless handlepole bolt $59.95
* Includes stainless nut and washer
RRP new lightweight pole bolt $54.95
* Includes nut and 2 washers, weight 4.2oz.
Pinch Bolts
XMetal / XScream stainless pinch pole bolts 65.89/pair
Thrust stainless pinch bolts 65.95/pr
(46mm length under head to end, OEM threads size)
Thrust longer stainless pinch bolts 65.95/pr (backorder)
(RRP and other thick billet brackets)
RRP pole steering cable holder kit 36.90
Pole Springs
Blowsion RN SuperJet stiffer HD pole spring 49.95
- fits all RN Superjets 1996-2020 and FX-1
OEM RN SJ pole spring new $74.99 sale 64.79
fits all RN SuperJets 1996-2020 and FX-1
RRP spring tensioner 24.95
Blowsion SN superjet stiffer pole spring 49.89
- fits all SN Superjets 1990-1995
2021+ SuperJet HD pole spring -Riva Racing $54.95
Kawasaki
Blowsion Kawi 750/800 pole spring 49.89
Blowsion Kawi 650 HD pole spring 64.95
Blowsion Kawi JS400/440/550 HD pole spring 39.95
Lighten that pole and lower upper body fatigue. Fits all years Kawasaki JS Model 300, 440 and 550/550sx. NOTE: Does not fit 300sx model.
Handle Pole Pivot Bushings
RN or SN Superjet OEM Yamaha pole bushings $10.99
(fits all SuperJets 1990-2020 and 94-95 FX-1)
RRP cast pole bushings 25.95/set
RRP billet and lightweight pole bushings 25.95/set
XS adjustable pole bushings 25.90/set
AC Racing pole bushings 29.95/set
Kawasaki 750SX/SXI/800SXR OEM pole bushings 9.49/ea
Kawasaki 440/550/550SX/650SX pole bushings-a/m 24.90
Oversized handlepole bushings for the Kawasaki 440/550//550SX/650SX.
(Your pole must drilled out the hole for these bushings to fit. These bushings are 7/8" diameter where they press into the handlepole.
Made from acetal/delrin.)
RRP Pole Bolt Spacer for CAST pole 35.95
RRP Pole Bolt Spacer for BILLET pole 35.95
RRP Steering stop/Chinpad Support 65.80
Thrust billet Steering stop/Chinpad Support 54.95
OEM SS Steering cable pole mount(U shaped) 9.95
Pole bump pads for hood
HydroTurf Pole Bump 1" pad 13.
(Has peel and stick for easy installation)
HydroTurf Pole Bump 2" pad
HydroTurf Pole Bump 4" pad
Pole Limiting Rope Kit
index.php
Limiting rope kit $40.90
includes:
-Stainless tray loop mount
-Stainless allen hardware with washers and nylock nuts
-Stainless carabiners -high quality 2x
-Stainless pole mounts -2 styles
-Sta-Set rope kit with elastic keeper and clip to pole base area
(High strength Sta-Set marine rope)
index.php
Handlepoles
XMetal XScream Billet Adjustable Handlepole kit $995.
Complete kit includes:
- Adjustable Handlepole
- Stainless steel pole mounting bracket
- Aluminum hull backing plate
- Dual pinch stainless pole bolts
- Chinpad
- Chinpad support/steering stop
- Breather Hoses
*Standard pole comes with -2 to -5" adjustability
*Precision All Billet 6061 Aluminum construction
*Black powder coated finish
*3 bolt slide system keeps adjustments simple with no disassembly required
*XS pole is drilled and threaded to accept UMI, RRP, and other steering systems
*Pole weight only 10 lbs.
XMetal Billet Adjustable Standard length Handlepole kit (Yamaha) 995.
XMetal Billet Adjustable Competition length Handlepole kit (Yamaha) 995.
(Also available without pole bracket)
XMetal Billet Adjustable Competition length Handlepole kit (Kawi) 995.
Xmetal XS stainless pole bracket 135.
(includes aluminum backing plate)
Xmetal XS pinch bolts/nuts 65./set
Xmetal XS pole breather tubes 2x 16./ea
RRP poles
RRP cast adjustable handlepole kit $799.
RRP billet adjustable handlepole kit $1,125.
RRP billet LITE adjustable handlepole kit $1,199.
RRP CBX adjustable handlepole kit $1,425.
RRP handlepole replacement aluminum tube 49.95
RRP Ninja Chinpad 320.
Pole Brackets
RRP billet handlepole bracket for SuperJet and similiar hulls 319.
(includes RRP breather tubes, billet hull side hood hooks, and hardware)
RRP Rickter billet handlepole bracket 319.
*for RRP and similiar style hulls like Tigercraft and WCF Vision where pole bracket fits in pocket on hull, and hood hooks are not on pole bracket.
(includes RRP breather tubes and hardware)
RRP replacement pole breather tube 39.95
Blowsion lowered single hole pole bracket 279.80
(includes breather tube and stainless hardware)
HSI SN conversion to RN pole bracket kit 249.
JetManiac's Steering/throttle/grips SHOP- ADA, RRP, Cold Fusion, ODI
Do u ship to the uk? If so how much roughly to ship rrp 50mm risers, cf riser bar clamp and s.plate, cf throttle lever, bushings, locknut, limiting rope eye and latch, odi rogue grips (silver ring). After the best system to go with my shmitty cable, hope to hear back soon.
Regards,
Trotty :)
JetManiac
Stoked
orlando
Regards,
Trotty :)
PM sent.
what would you recomend with the shmitty cable if i installed it?
5'4"-5'5" 175 pounds, i want a quicksteer system with the least haslte.
shmitty's kit uses bushings, works good with the cf turn plate, but handle bar?
and i knida dont like the idea of messing with my chin pad, is it essential?
plus any recomendations on intake/plate/cone?
sumthin not too agressive but different from stock.
i have an 011 btw
thanks (5/5) :D
Michigan
Would that cast aluminum throttle lever for 34. need an adapter or can I throw that right on my SN stock set up?
I also want a ratcheting hood strap, I'll pm once I have enough posts.
Will the universal cold fusion turn plate fit a 93 750sx? 1-3/4" shorter sounds pretty far ahead that might affect steering?
Sent from my iPad using Tapatalk
