- new jersey
Had this Hull over a year now , finally time to start assembly.
History is this is an early version of the havoc , I think owned by flyinryan , then his friend , now me.
It’s been professionally repaired on bottom of the hull and repainted by a composites company prior to me purchasing.
I bolted up the pole mount and comp- length xscream pole but it looks a bit off center. Not sure if the bushings are doing this or I need to ream out the pole mount bolt holes to shift it?
I plugged the scupper on the inside and plan to run a bilge pump. ( wing-nut plug do not permanent)
There is no foam and it has the thrust mini drains. Thoughts on foaming before I turf?? It’s a short hull so I’m not sure if would even matter.
Waiting on jetmaniacs ported 718 w/ 38’s. Ill be running a b- pipe , lighted flywheel and enhancer. My thoughts are to keep it simple now and see how it goes. Any tips /comments please post em up
