Mouthfulloflake
ISJWTA member #2
- NW Arkansas
the melted hose was before I had it adjusted to get the 160 headpipe temps.
its a fine line between melting stuff and too cold!
Get rid of that pipe and get you a Speedwerx pipe. There are no adjustments and it will turn 7800 if the ski has the power. All you have to do it bolt it in and hang on. There will be more power there than any pipe you can run.
And while you are looking for pipes. Find me a Speedwerx freestyle version. I think you would want a race version because you like the RPM's.
But about your pipe. IF 140 degrees chamber temps are melting hoses then you have a problem with your temp gun. 140 is really cold. when you pop the hood after WOT running the water should dance off of the pipe. Not stick and boil. Water dancing temps are around 300+ IF you are just braping around then the water should stick to the pipe and boil. AND it will be LOUD remember my ski....LOL
