dbrutherford
Parts Whore
- Fairmont, WV
But I have to charge $20 interest for the delay in the coupler shipment earlier this year...
pony up posers.:wave:
My thoughts exactly!
No thanks If Diceman will be nice enough to send me my bedplate,I can figure it out on my own!
That you can my friend. Looks like your getting that plate soon, and CHEAP I might add!!
I don't think you need pics to figure this one out!
Did you make spacers to mount the cases to the bed plate?
And the bearing housing will go up and down a little as well.From my dealings with this the case bottom mounting to crankshaft centers on both were damn near identical,I will know a little more tomorrow if the bedplate shows up then.
I strongly suggest that whatever you do you replace those four case bolts with studs,they are only 8mm bolts,they are not going to take a lot abuse,the stock Kawi engine mounting bolts are 10mm and so are the stock Yamahas.Remember most of us are beating the crap out of these hulls ,yes even me!
I have an idea for another product for these but I have learned it is better to keep your mouth shut till it is built.
Your no fun.
I will give you two dollars then.
