If you go out side and have a look at your victa lawn mower you will see a two stroke that has air flow that goes in the intake and up to the bottom of the piston then into the transfers when the primary piston rises.
Two strokes that have a pipe actually pull the mixture up the transfers.
I wouldnt normally post pics but I dont do this stuff anymore. Every one just buys billet engines and thinks they are the gun
Here is a set of cases nearly finished
A well set up engine will have great bottom end as well as nice top end as well. Get the blow down right and you will scare your self.
The bad thing about the 62t platform is the really really bad transfers there is alot to be gained in there as flow slightly more than a maccas straw and there angles are all to hell
http://s215.photobucket.com/albums/cc79/waxracing/?action=view¤t=001-37.jpg
