New HPE 4mil long rod "bolt in" stroker kit. This kit comes with an ADR/HPE exclusive 72mm stroker crank built with 133 rods, HPE billet stroker baseplate in your choice of color (red or blue anodized, and machined aluminum), HPE stroker domes with Orings for ADA heads, extended dowel pins, new pin bearings, OEM crank seals, and 3 base gaskets in different thickness for fine tuning your squish.
This kit is set up to keep port timing correct, you will gain power right off idle up to peak rpm. The long rod and stroker baseplate combo work together to increase crankcase pumping efficiency, torque and hp. Available for 701 and 760 bores from 81mm to 86mm.
The kit price is $895 as shown
Call or txt HPE @ 714 931-3860
