superjetguy
It's hard to speak without a tongue.
- lake hogan
Guys, some of you know i haven't had the best of luck this year with two top ends toasted on my superjet. Most recently my carbs developed a leak and toasted my pistons and I ended up loosing a circlip also. So I got a new to me cylinder and new Pistons from the buzzard and slapped it together, I rebuilt my carbs and changed jetting. I believe it's 135/70 popoff is 55 psi on both, screws are 1.5 on bottom and 1 on top or something close. It is running horrible, bog off bottom and seems boggy everywhere. Compression is great at 190 I'm running 100 octane with Lucas 40:1 mix. I just want some suggestions on what to set jetting to or even my screws. Thanks.
