Foximus
CFL Cheapass.
- Oviedo, Fl
I as well have a bunch of solid aluminum bars to sell. I drill out the last 6 inches on either side of the bar. Works to keep the weight down a bit and it acts as a vacuum to keep the grips on.
just a quick search a couple builds i know of using carbon bars
first 2 are duners have yyou seen the jumps they make. the 3rd one is a drag bike
:shocked: sweet!
That looks like an old "FLITE" on there!!!!!!!!!!!!
troy, waterdawg bars are real nice
I feel like I have less leverage on 4 degree vs straight. Back in 2006 I took my SXR with 0 degree UMI and Yamacat's Limited SXR with my old 4 degree bars to the Lake Norman race. I had the hardest time on hers, actually made me get arm pump from the 4 degree bars
You might try sanding a slight radius on the edge of your clamping surfaces, you might have a hard edge that's digging into the bar when you tighten the clamps that's causing localized fatigue, as somebody mentioned.
