Ok i'll add:
5mil * 85.5mm RD (Lamey cycl) with some real serious compression
02 SJ
RAD flywheel, MSD enhancer
all the typical go fast goodies
stock pump blueprinted
wet wolf freestyle cone
BIG bore Protec nozzle (close to 88 or 89mil if not mistaken)
Protec at the time offered a few different nozzle sizes, i bought the largest and I believe Paul (LPW) opened it up even more
JD deep intake grate and ride plate
Hooker 9-15 (out of the box model)
I have used:
hooker 10-16 (tweaked (non-meth lol))
Solas (Impros modded) 13-15 (cuts from 3mm to 5mm), 13-16 (3.5mm cut) and 13-17(3.5mm cut) (these were all tweaked as well, and Dave and I worked on various tweaks to these) my fav is the 13-15 tweaked sitting on my garage shelf
each ones has a unique sweet spot, and to me it's all personal taste as to what you like and works for your style
the 9-15 fits what i want, great POP off the low end, and the motor has plenty of muscle to pull at various speeds, although at upper mid range you feel where the prop drops off (meaning the pull isnt as strong, again its a bottom end prop)
keep in mind, I have Blowsion hull extenders, i'm VERY heavy (figure at least 300 pounds when in the water wet with gear on), have a reinforced ski, and weight added in the nose (plus the addition of the rayce weights if needed)
I can only wish this prop was made in carbon fiber (if that is possible) or Ti, something light to spin up even faster/more crisper, i think that would be interesting to see that difference
