hornedogg79
dodgin' bass boats
"Blue" is the guy that does the porting.
61x Cylinder- your cylinder sand blasted then bead blasted, new anode installed if needed, painted and baked on beautiful satin black finish
JetManiac/Blue 'Freestyle' porting designed for low end power but good perfomance all around.
Fresh bore to 81.5, 82, 82.5, or 83mm, chamfer/hone, cleanup decking to head and exhaust gasket surfaces, ready to install
New Pro-X piston kits with new wrist pins, clips, and wrist pin bearings
Gaskets- new base and exhaust gaskets, US made quality
New carb jets and springs for oem 38's included
*option add 75. for more aggressive porting, bore to 84mm(760cc) and modify oem sleeves for even more brapp.
just arrived today 61x cylinder (ffom jetmaniac) 83mm bore, ported, plus extra porting. i have not even put it togeather nor is my ski ready for it at the moment. the quality of this top end kit is just ridiculously clean. i mean i have seen other excellent! machine shop's cylinder's that r ported ( jetskis,dirtbikes,scooters ect.) and $ for $ this kit is every bit of the same work no questions hand's down if not cleaner (my opinion) anyways from the looks of all my new parts this thing is going to RIPP pretty damn good.
Would there be any difference in performance with the 62t case versus the 61x case. If so is it noticable to the average rider that wants a bit more power? thanks
I cant give you a 100% yes on that but everything i hear/read says that a 61x cylinder with 62t case's over the 61x cylinder 61x case's (my setup) is the difference between the hooker you get on craigslist or the one standing on the corner downtown.
Can you purchase this kit without sending you a core. Like if you have a cylinder that has a nice bore already, or in my situation where im wanting to buy a waveraider with 62t/62t to get a 61x cylinder and throw into a superjet.
^^^Add 100. For 61x cylinder (no core provided by you)
sweet, and if i pick up a 61x cylinder, does it matter the condition of it considering its just going to be bored?
Perhaps, but why would you? Porting without a bump up in compression is like a steak without salt and peppa...Would it be ok to run a stock head with this top end?
