Thanks Chris! I can't wait to put the engine together! @JetManiac
Hey there... just to confirm $650 w/ a core returned? +Ship to Canada?
How do I get my hands on one of these kits?![]()
61x Cylinder- your cylinder sand blasted then bead blasted, new anode installed if needed, painted and baked on beautiful satin black finish
JetManiac/Blue 'Freestyle' porting designed for low end power but good perfomance all around.
Fresh bore to 81.5, 82, 82.5, or 83mm, chamfer/hone, cleanup decking to head and exhaust gasket surfaces, ready to install
New Pro-X piston kits with new wrist pins, clips, and wrist pin bearings
Gaskets- new base and exhaust gaskets, US made quality
New carb jets and springs for oem 38's or sgl 44/46 included
*option add 75. for more aggressive freestyle porting and modify oem sleeves for even more brapp.
We can provide 61x core cylinder (125.) if needed.
nice!726cc Ported Top End kit, Painted custom gold/yellow and reassembled(along with some other JetManiac goodies)! Can not wait to get this thing installed! kit and instructions makes this project practically brainless...
Thanks again Chris
Did you paint that or did JetManiac boys do it?726cc Ported Top End kit, Painted custom gold/yellow and reassembled(along with some other JetManiac goodies)! Can not wait to get this thing installed! kit and instructions makes this project practically brainless...
Thanks again Chris
I am running dual 44sbn on a 62t/61x. Can you help me dial that in? Want to order this from you and need to know if my setup will work out or if I need to change it up. I find 50/50 opinions on running 44’s but it’s what I had when I built the ski. Currently at 718cc.
We can provide 61x core cylinder (130.) if needed.
For this kit, do I send you my current cylinder? And what is roughly the turnaround time?
If I buy this do I need to run a different cdi? Or can I use the stock electronics for now? I wanna make the most power I can but on a budget. Just need to get through the rest of the summer and then get a different![]()
if I buy this do I need to run a different cdi? Or can I use the stock electronics. I wanna do what ever I can do for upgrade in the future just don’t have the money to do all of it at once.![]()
