New JetManiac/Blue freestyle Ported Top End Kit $879.
I’m looking to replace my current 760 cylinder-85mm bore with something better like a power valve. I have 62t cases with dual 44mm carbs and ADA head. What do you recommend that can be shipped to California by this Friday?
61x Cylinder- your cylinder sand blasted then bead blasted, new anode installed if needed, painted and baked on beautiful satin black finish
JetManiac/Blue 'Freestyle' porting designed for low end power but good perfomance all around.
Fresh bore to 81.5, 82, 82.5, or 83mm, chamfer/hone, cleanup decking to head and exhaust gasket surfaces, ready to install
New Pro-X piston kits with new wrist pins, clips, and wrist pin bearings
Gaskets- new base and exhaust gaskets, US made quality
New carb jets and springs for oem 38's or sgl 44/46 included
*option add 75. for more aggressive freestyle porting and modify oem sleeves for even more brapp.
We can provide 61x core cylinder (125.) if needed.
How do I get my hands on one of these kits?
5704665801 - Chris
726cc Ported Top End kit, Painted custom gold/yellow and reassembled(along with some other JetManiac goodies)! Can not wait to get this thing installed! kit and instructions makes this project practically brainless...
Thanks again Chris
I am running dual 44sbn on a 62t/61x. Can you help me dial that in? Want to order this from you and need to know if my setup will work out or if I need to change it up. I find 50/50 opinions on running 44’s but it’s what I had when I built the ski. Currently at 718cc.
JetManiac
Stoked
orlando
pm sent
We can provide 61x core cylinder (130.) if needed.
For this kit, do I send you my current cylinder? And what is roughly the turnaround time?
Minnesota
If I buy this do I need to run a different cdi? Or can I use the stock electronics for now? I wanna make the most power I can but on a budget. Just need to get through the rest of the summer and then get a different
if I buy this do I need to run a different cdi? Or can I use the stock electronics. I wanna do what ever I can do for upgrade in the future just don’t have the money to do all of it at once.
