youre crazy thats WAYYYYY to big a jump...
sillymaniac
14/19 c75 is SS 849 power...not 701 power
Even more reason it shouldnt be cavitating. Light hulls will scoot, heavy hulls will cause more cavitation. You should use like a 9/15 or 9/17 Hooker C75.
Chris I had to do the same thing on my Superfreak hull, light hull takes more prop! I think my Rickter with the SS could go up to the next pitch now.
I bet you 14/19 will be right on it on that hull
Idok and Foximus, I can now conclusively tell you that you are both wrong.
The 14/19 is perfect with the jetmaniac ported motor in this hull. It pulls hard out of the hole and at all rpms with no hesitation. As josh and lucas said, lightweight hulls need more prop(higher pitch) not less. Less weight means the motor can accelerate the impeller in the water faster.
