JetManiac's Electrical Parts Shop
Find almost any electrical part to build or repair your ski right here. High quality new, used, and rebuilt OEM yamaha parts. Buy with confidence, JM parts are professionally inspected and selected, and even used parts are covered by JetManiac's satisfaction exchange warranty.
Electrical Box (Ebox) parts
Ebox gasket -new OEM Yamaha 19.49
Ebox rear -OEM aluminum, bead blasted and epoxy painted 39.
Ebox front cover -OEM, clean used 25.
Ebox fuse cover cap -OEM, used 6.
Ebox fuse cover cap gasket -new OEM yamaha 7.90
Ebox fuse holder assembly- OEM clean used 11.
Ebox temp sensor -OEM, clean used 15.
Ebox blank grommet 6.90
Ebox screws -new OEM SS 2.39/ea
Or clean used 1.25/ea. (when available)
Ebox OEM internal hardware kit (8 clean bolts) 8.
Ebox to hull mounting bracket -new OEM Yamaha 19.89 sale 18.90
(fits 1990-2019 SuperJets and 1993-1996 WaveBlasters)
SS ebox bracket mounting hardware kit to ebox and to hull for 2 brackets 6.
Ebox rear direct to ebox back mount M8 bling washers 3.49/ea
Ebox Start/Stop switch SJ OEM ebox side harness -new 78.90 sale 64.95
Replacement OEM Start/Stop connectors 12.90/set
(1 Male and 1 female connector housing for switch side and for ebox side, 4 crimp on connectors, and 4 rubber seals)
*2 sets needed to replace all connectors on switch and ebox. Good for TL setups as well.
CDI units
CDI unit (6m6, 61x, or 62t) -OEM Yamaha, clean, used 89.
(30 day exchange warranty)
Yamaha OEM CDI with adjustable Rev limit 139.90
*Yami OEM CDI tested and modified by OCD solutions with adjustable Rev limit
MSD enhancer for Yamaha 369.95 sale 339.95
Zeeltronics 760 programmable CDI 296.90
(Comes programed with the WAX curve)
Starter solenoid/relay -OEM clean, used, tested 39.
Or
Starter solenoid/relay -New OEM Yamaha 99. sale 81.90
Voltage regulator/rectifier OEM clean, used 18.90
Battery /ground cables
New
OEM ebox to battery red power cable 45.
New
JetManiac custom ebox to battery red power cable 29.90
New
JM custom ebox to starter red power cable 29.90
New
JM custom battery to starter black ground cable 29.90
OCD Solutions Surf Armor Battery Cable kit 79.90
HD marine grade custom made power cables.
(ebox to battery, ebox to starter power cables and ground cable.
New JM custom length TL total loss battery and ground cables available
OEM style ebox and stator connectors
(also good for total loss wiring)
5 M/F Terminal set 8.90
(5 male terminals and silicone boots, 5 female terminals and silicone boots)
10 M/F Terminal set 14.90
(10 male terminals and 10 silicone boots, 10 female terminals and 10 silicone boots)
Ignition Coils
JetManiac Yamasaki all NEW OEM ignition coil 149.80
New OEM Kawasaki ignition coil (hotter spark, lower price) with NEW Japanese OEM wires and black, red, yellow, blue, green, white, or orange sheathing and NEW yamaha OEM ebox grommets and MSD boots/terminals installed and surf sealed
This is the ultimate coil for any ski but especially for surf use.
*fits Yamaha '90-17 SuperJet and '93-96 WaveBlaster
OCD Solutions OEM rebuilt coil 106.90/no core
OEM coil -reconditioned, cleaned and tested with new wires, MSD boots, and terminals installed.
OEM Yamaha ignition coil -clean, used 58.
(add 18. for new MSD boots/terminals installed)
MSD spark plug boots
MSD spark plug boots and crimp-on terminals kit 13.
(kit includes 2 HD silicone boots and 2 terminals)
or 2 kits for 10./ea
MSD crimp tool 13.90
MSD replacement crimp-on terminals 2.50/ea
or 6pk for 12.
Triple
MSD spark plug boots and crimp-on terminals kit 19.50
(kit includes 3 of each)
MSD boots, terminals, and Red retainers kit (2 of each) 29.90
MSD battery quick disconnect kit 32. sale 21.80
NGK Spark Plugs
BR8HS solid tip -standard length for stock Yamaha size
BR8ES solid tip -longer reach for Yamaha with a/m head or all Kawasaki
MSD Total Loss parts
MSD TL ignition coil
MSD TL pickup
Custom TL plug wire sets
Custom TL power and ground cables
SeaDoo OEM total loss relay (with plug in wiring harness) 49.95
Shifty mod for TL 99.80
Bilge pumps and bilge electrical parts here:
New - 'Water Out' Shop -Bilge Pump, Scupper, Versiplugs, Hood seals, Billet outlets, hose, mounts, etc.
