"js/sj" Porting
Status
Not open for further replies.
Epoxy used to fill casting voids(areas that factory leave for various reasons... Less manufacturing costs mostly.. ) added support/structure to achieve shapes one desires.. and strength...
Copy???? I don't make knock off footholds/sponsons. =-O:)
Sent from my XT1080 using Tapatalk
SuperJETT
none
As someone who has been around jetskiing longer than most (23 years now), I'd suggest you step away from the keyboard for a minute because you're just making yourself look dumb.
To paraphrase your post above: it's not about flow in the cases, it's more about flow from the reeds that are in the cases to the transfer ports that are connected to the cases.
Air must get to the combustion chamber. With the least amount of resistance/distortion. Throughout intake process it is not a straight "flow"
Two stoke... Up/down... Once all intake charge is "in". Piston goes down and creates "primary"compression whichs causes "charge" to go different ways to the the place it has to go...the combustion chamber... Not the same "flow"as like a 4 stroke..
It actually is migrate is a better word than flow because it described more of what's its ACTUALLY doing
SuperJETT
none
I guess 4-strokes are just free flowing setups then? No up/down, no valves or anything that control air?
N3vrSat1sfied
Military Member
Fort Worth, TX
flow
verb
  1. (of a fluid, gas, or electricity) move along or out steadily and continuously in a current or stream.
  2. go from one place to another in a steady stream, typically in large numbers.
noun
  1. the action or fact of moving along in a steady, continuous stream.
  2. a steady, continuous stream of something.
mi·grate
verb
  1. (of an animal, typically a bird or fish) move from one region or habitat to another, esp. regularly according to the seasons.
964chris has there been any problems with "water migration" or thermal concerns with your setup?
Status
