- Grand Rapids
Flowgration.... Why do oem gaskets use various "holes" to control water direction?
Sent from my XT1080 using Tapatalk
Honestly, this is the best thread in the history of this site. It is almost as funny as Dumb and Dumber. Just when you think someone can't be any dumber, they prove you wrong. lol
It's better to keep your mouth shut and let others see you as a fool, than open your mouth and prove to them you are.
Scottie
If u can build the best skis on the east.... Why can't u install bearings into a solas pump?? This thread started in an ok way. But the bully posts make no sense. Maybe some people should use quality bearings rather than the least expensive.Honestly, this is the best thread in the history of this site. It is almost as funny as Dumb and Dumber. Just when you think someone can't be any dumber, they prove you wrong. lol
Scottie
So, You said that is the wrong epoxy to use. Would you use the metal kind, looks like clay, you mix the two parts together? Is that the proper way to fill those holes?Epoxy used to fill casting voids(areas that factory leave for various reasons... Less manufacturing costs mostly.. ) added support/structure to achieve shapes one desires.. and strength...
Copy???? I don't make knock off footholds/sponsons. =-O
