- Cleveland Ohio
I have to say that my SXR 800 motor with a pipe and flywheel and stock EVERYTHING else including impeller hits identical to every perfectly tuned 701 I've gone up against (All have pipes, MSD, impellers, heads, porting). Even with an almost identical hull)..and this is with a lot less mods and 30 pounds lower compression. The SXR 800 cylinder porting makes all the difference from the 750s in the low end department. I've ridden a almost 100 different skis and am still very happy with my Kawi's power. I imagine if I port it and bump the compression to 180 and get an impeller, I'll smoke 701s all day long.
The main thing holding Kawi motors back has ALWAYS been the heavy hulls.
Basically, if you are going aftermarket hull, I don't think it matters which platform you run (run what you brung).
If you are keeping stock hull, go Yamaha (hull is that much lighter, making it feel like you have that much more power)
