- Charlotte NC
Looks like tons of throw! Good job.
Just need to get a cable to hold up....
What length rideplates do you use? The only phantom I've ridden has the uptilt nozzle, but an extended rideplate and it rides awesome! Mine came with a flush cut rideplate.Try to find a 65u -10 it's all I'll run on my phantoms if you want to ride a little bit more nose high
I use up swept with a flush plate I'm a pretty small guy 145# so if I don't it rides pretty flat
Cool! Were the same weight, I'm 5'11" ~145lbs, so I'll keep that in mind! I think I know where an upswept nozzle is...
Thought yours was an upswept nozzle? Mine is straight, but I do have an upswept nozzle laying on the bench.
weld a little nut at the bottom of your end nozzle , insert a screw that pushes against trim ring , then u can adjust / preload trim up nozzle position .....
it helped a ton with Kelly
So, I just found this thread. I'm so excited to see this on the water soon! Think you'll have it ready by DobieFest next weekend?![]()
That's a great idea!!
Nicely done. Is there a reason you didn't want to to open the center hole on the xmw piece to allow OEM bushings and a larger bolt?
Yeah @ducky I can get you one without OEM bushing and center bolt those pieces eat up a decent amount of the cost which I would obviously pass along
Welcome!thanks for the ada coupler set
