I wonder how significant the vacuum losses would be with the additional hose lengths. @Jyzmbe how long of a hose are you using?
If I am not mistaken that will weaken your pulse signal (Pressure).
Found a pressure drop calculator on the internetz. For a 10cm long tube its about a 5 psi drop. For a 30cm long tube its a 15 psi drop. this is making a whole lot of assumptions though.I wonder how significant the vacuum losses would be with the additional hose lengths. @Jyzmbe how long of a hose are you using?
That's a strange looking carb setup to me. What it looks like is that the pulse line broke off the left carb and it has been "repaired" with that 90 degree brass fitting. Then it looks like the right carb"s return is feeding the feed for the left carb, which to me seems crazy but I have been surprised before. It should be both carbs feed from their own line from the tank each with a filter and T the two return lines together and run them back to the tank as one. I would question the whole setup jets and all on those carbs if you have never run them before they way the setup came
Ok, that is what my husband and I were thinking with the one pickup, but wanted to check since we were only guessing.oem 44's came with that pulse line 90 on the rear carb.![]()
As far as routing it looks like how @cookn said. They probably only had one tank pick up so only feed the front carb. X2 on doing each feed individually, and T the returns together.
What do these routing styles have over the type I posted? Better cooling, more efficient, less hose length...?Im a little late to the party but Pulse lines should be as short as you can make them and equal lengths. Also @Jyzmbe is right for water lines. Ive always ran bpipes this way:
Xscream has their own water routing, dont have a diagram, but heres a photo: head to a t- one way to bypass, one to stinger, head to front of head pipe, bottom of head pipe to bypass, two intakes from pump to bottom of manifold. (my bypass fittings on this ski were in the top right of that photo FYI)
I'll be running the 2 feed lines and T-ing the return. Seems easy, but I've been wrong before.
Filling from the bottom will keep more positive pressure, if you fill from the top, the pressure may not be as well and cause less water to squirt into the chamber.Yeah that's how you should do it or the way it should be done for a built motor. The way he had them is how some came on a factory couch.
As far as b-pipe water routing, there are 2 ways as Jordan posted. The difference is one way fills up the head pipe from the bottom, the other fills the head pipe from the top. personal opinion, factory pipe will say fill it from the bottom, so that's what most do.(the routing picture Jordan posted)
Engine, ebox, waterbox and trim are in.
Didn't realize a SJ battery was so freaking huge. Any small battery I can get for this weekend locally? A Grom battery is small enough, just not sure if it has enough juice.
