chixwithtrix
Addicted
- Houston
A little preview of my bits from @OCD Solutions
Squee! Looks nice with the blue thank you for all the detail.
No issues with the starter before. Started instantly and no sparks. Good cranking.So, it seems your starter switch and starter relay are working, but you're getting a short from positive to negative, possibly across the starter motor. Any issues with this starter before?
I'd check to see if there would be anything to short across the starter motor from positive to the case or ground.
All my battery cables were in good shape, I wanted to replace them with OCD cables purely for beauty's sake. Ski started fine as far as cranking before I messed with the ebox. I did have an intermittent start issue that the system was totally dead...no clicks or sparks, nothing. Was remedied by jiggling the start/stop switch wires at the ebox, no hesitation when it did start.You didn't mention your ground cable. What kind of shape is it in? It looks like the spark is trying to jump from the motor case to the battery....
The battery zip ties were a first day stop gap for the first ride day test that I just did circles making sure the engine ran.Ashley, Do yourself a favor. Order the OCD Battery Cables and Please Please find some battery straps for the battery. Zip Ties Fail.
Having my husband order/buy new BR8HS plugs at the powersports dealer he works at tomorrow. Could the bad plug connection be causing the issue? I don't want to try starting it again like it is in case I fry something important. Does the wiring look like it is generally in the right spot?That is quite impressive!
I'd be surprised if 12VDC can jump that kind of gap so I can't help but wonder if there is some secondary ignition voltage at play there. You mentioned the plugs didn't have the thread on caps, any chance you can swap in some different plugs with the proper tops so the coil is properly terminated?
Good info, thank you. Since I wasn't having an issue with the positive and ground cables I was going to wait until I needed to take off the bpipe to swap for the nice looking ones. But I guess now is the time lol. I'll put in the new plugs, try it like it is, and if it doesn't work I'll install the new pos and neg I got from OCD.It's hard to tell from the pics but it looks like everything is in place to me. I would swap out that old ground cable and clean the mounting areas and see if that makes any difference.
I can't quite make out the video. Is the spark jumping from the negative of the battery over to the carbs or positive to negative as mentioned above?
The stock electronics are capable of building up to 40,000 volts if it's not given a path to ground at a lesser voltage. This is why they encourage you to never crank the ski with the plug wires disconnected. The plugs should fire and effectively discharge the coil between 12,000 and 14,000 volts. If allowed to climb higher, it will find an alternative and much more expensive path to ground.
This is also why gapping down plugs may resolve an intermittent spark issue. Not only does it produce a nice spark at the plug, it also keeps the voltage from building up high enough to start finding alternative paths.
No multimeter, might try to see if a relative has one. Not too sure how to use them properly. I have just enough electrical knowledge to be dangerous.A quick check to help diagnose would be to check the resistance between your battery ground and ebox ground as well as resistance from battery ground to motor case. Do you have a multimeter?
