- Long Island
You can jump your solenoid with a screw driver across the terminals. This will tell you if your starter is bad or not.
You can also take the wire going to the starter off the solenoid. Put a voltmeter on D.C. and check the post for 12v when you hit the start button.
Set the volt meter to ohms and check your start switch for continuity.
3 quick tests and you'll know what's wrong and what to replace
