Got it home, first obsevations. Build very well, hull is solid definitely vacume bagged and infused. Hull kit with pole and bracket, motor mounts, hood, is under 78lbs.
Paint job is 8 out of 10
Turf job is ok
The handle pole is ok, does not compare to my BUN as far as milling goes...
Over all hull is built very well, hood opening is unreal lots of room! Very nice motor mounts looks to be larger than oem, more like out of a sitdown ski with big motor application. Came with custom kawi driveshaft 23 1/4 long its nice,but ill be using
one of my HBC Titanium versions for weight savings. Hull is about 73 inches long
(lower deck) nose to back. Topdeck is all custom dont see any lines that look usual.
Lower deck is sxr based no secret there, from nose to mid of hull is custom. Will get lots
of pop from this hull. More pics to come, pump install next!
No tubes in the Hood . Guess your fresh air enters only thru the pole ? That should be dryer, but will it be enough for a large displacement motor ?
