masterblaster
X-H2
etx9 and lith batts are for skis that start with 3 sec of cranking,your fine. If you have a ign thats funny about starting or no primer,good luck. IF your ski sinks,just pull it and put a bigger batt in to get it started. Ive had good luck with the wps lith,advance warrants them for a yr,no questions asked,its worth the price even if it only gets you by with a batt for the yr.IF you ride a heavy hull or b1,just run a brick batt,youll not know the diff anyway
