:tomato: You can also get glass version of the X-jet for $3800..........comes in whatever gel coat color you want, billit handlepole bracket, hood, footholds, 2 scuppers, pump shoe (144 or 155mm). Various options available. I think the lightest Jeff will make a glass hull is right around 90lbs.........hood is an additional 11-13 I believe. So you would be looking at a hull that is right around 100lbs depending on what you have done to it. Several bottom decks to choose from depending on your riding style......bottom decks that you cannot get anywhere else! :wavey: Contact Waterdawg Kustoms for the up to date info.. :Banane37:
hone:
