- seattle area, Wa
Just an fyi, when you install the 61x nozzle you need to remove your engine and midshaft from the ski to align your pump/driveshaft. I have found that the mounting ears(where nozzle bolts to hull) on the 61x nozzle are slightly thicker that the oem 08+ nozzle. This will create an upward angle of the driveshaft and must be reshimmed/aligned in order to avoid vibrations.
Notching the oem nozzle is very simple and creates less work overall considering the intricate realigning process on yamaha setups.
Edit:
Or you can simply machine the ears of the 61x nozzle down to the exact thickness of the oem nozzle and just keep it on the down-low if you make it to a big race where you might get teched
Edit:
