- North Carolina
I know the drive my be a little long (ha ha) but your welcome to ride it anytime.
Stock bore 760
Milled the cylinder base .065
ADA head I don't remember the dome size. Recut for.060 squish and 200 pounds of compression.
Cylinder ported by me.
Cases ported by me. I didn't fill the fingers.
Vf3 reeds stock manifold with cross over filled.
Stock dual 44 stock air box with one screen
Stock 650 stator and flywheel. Stock coil.
MSD enhancer. 0 degrees static timing.
Riva freeride pipe.
Aluminum water box from a blaster 2 I cut up to make fit in the sj hull.
Running 100 ll av ga and castor 927.
9/15 prop ( might go to a 10/16).
Stock pump with no mods.
My next mods might be 0 flywheel, mag pump bore the nozzle and freestyle pump cone. There is definitely more vibration in the low rpm's then from the 650 or 701 but not as bad a a 1000 I have ridden.. I attribute this to the timing advance from the msd. Can't wait for an aftermarket hull.
Stock bore 760
Riva freeride pipe.
