so you decked the cases instead of the cylinder?
I thought I should give a better answer to this. Yes, I decked the cases and had to bore them to accept the larger sleeves and add a second pulse nipple as they were a standard set of 62t cases, not the 760 cases. Also, when you do this you have to grind the corners of the bottom of the cylinder sleeves for clearance as you have now dropped everything by .065. Its not a lot...just worth noting.
Decking the cases is super easy for any machinists to do. I had a local guy do it for a case of beer (granted he is a buddy). Also, I bought a used head with really crappy domes off ebay for like $60 shipped. Because I had to have the domes adjusted anyway I bought a 701 set up as they are common and than had the same machinist cut into the domes to adjust for clearance ,proper squish, and larger bore. The domes cleaned up really well due to the amount of material he had to cut out. Saved me a ton of cash over buying a new head and clean domes.
I had the cylinder and pistons from a previous motor set up but here is the cost I had incurred.
1. Used head : $60
2. 62 t cases (I traded parts for these so free but usually $175-$200)
3. Machine work $100 (again I had a buddy do it for a couple cases of beer)
4. Dual 44s, mani and reads $150. (I was able to trade parts for these as well)
5. Gaskets $100
My actual cost was only about $175 but I had a lot of parts to trade/ ect.
All porting was done by another buddy using the sport port template. Again on the cheap (Beer)
For the money I spend I am blown away at the power
