low rise handlebars
Flash-FX
No Square..No Round..FX-1
Here's what I've been running for a while now...no problems so far. It took like 5 minutes to get used to. The E-13 mounting brackets move the bars forward about 3" without hacking up the pole (my 2nd option). Yes, the downhill bars are thin, but seem to be way more rigid than the stockers that break after a few rides.
They are mounted on a Umi steering plate, trimmed down.
Delaware
Those don't look like low rise to me.. just 3* fat bars or something similiar. But if it works for you.
What's the rope setup in the 2nd pic where your stock pad would bolt on?
Cannibal
Tasty Human
Summit Lake, WA
Where does one get these E-13 mounting brackets? Google was no help.
Bay Area
dude just buy the rrp bracket an bars its really that easy! i will get my ski back in the next few days an show you guys how easy my setup is.
Flash-FX
OK...Perhaps this low-rise handlebar test is just another part of the "FULL CIRCLE ENGINEERING*" adventure. But for now, it seems to work pretty good. The center of the bars is re-located closer to the pivot point, which makes steering seem more natural, verses the standard "swing", that originates from way back when....the Kawasaki 440 days. These bars are considered to be low-rise (see new pics). I'm not trying to sell anything here but I'd thought some folks might be interested in experimental options. This is the "low rise thread"....right?
Bars- $29.00
E13 mounts- $76.99
From JensonUSA
And about that rope, it's the attach point of the limit strap...Simple and it works good too.
* "Full Circle Engineering" is when you try to re-invent something and it doesn't work out, then you go back to stock.
Cannibal
Tasty Human
Summit Lake, WA
Found some 7/8 center riser bars that might be worth trying for those interested.
Don't know the center spacing, so you might need to call to make sure they fit the clamps on whatever turn plate you are using.
$27.96
$61.56
I just picked up these trim and throttle levers for $14.40 each
Delaware
$27.96
Those first ones look decent especially for the price. One thing might be worth mentioning again is that mosts' preference would be to have a bar with no rise/sweep, whatever the term. Some of the ones I researched made awkward wrist angles in different pole positions. The RRP and new Blowsion are zero degree in any position.
FyrHazard
Ski Eat Sleep Repeat
Iowa
I love the look of those pro-taper style bars. That's now on my to-do list. thanks for the pics everyone!
let me tell you boys how i run RRP fat bars/mx style bars!!! i have a umi pole with a tbm turn plate! i got the bars from blowsion plus the extended clamp for the other bars he sells! i drilled the holes an clamped it on! simple
RRP 75mm Fat V Handle Bar - 28.6mm
75mm x 28.6mm Fat Bar for closed-course racing.
Item #: 03-05-134 Price: $69.95
Product Details
RRP Fat Bar Steering System
Extended base plate clamp for straight Fat 28.6mm handlebars. Riders using the FAT BAR Steering system with the Straight Fat Handle Bar may have to use this extended base clamp to avoid throttle lever interference with the chin pad on some applications.
Item #: 03-05-068 Price: $39.00
Product Details
Any pics?
