Vumad
Super Hero, with a cape!
- St. Pete, FL
So fitting this pipe has been a nightmare. Not from anything wrong with the pipe, because it is very well made, but from fitment issues with my existing equipment and me not ordering the correct parts I needed.
First thing I noticed is that I ordered the wrong stinger size coupler. I bought a 2" and needed a 2.25". Only place I can find that has a 2.25" (other than online) is an hour drive.
Second issue was rather minor, but still found it annoying. My water routing had to be redone. I needed Y fittings and right angle barbs. I searched all of the local hardware stores and no one had exactly what I needed. The manifold has 1 eighth inch NPT and 1 quarter inch NPT. Odd. I also needed some reduction Y's from 1/2 to 3/8. No big deal, I improvised. I had some 1/2" Ys already and adapters, and I have 1/4" right angle barbs and a 1/4" NPT tap.
Third problem is how large the waterbox is. I'm running a limited slip 5 gallon tank and there is just no way that tank and waterbox are going to fit in this hull.
I have at best 4" of clearance on the waterbox side. The waterbox is 5". I am probably going to pickup the new 3 gallon tank limitedslip is making, but in the mean time I ordered a kart tank. This is the biggest disappointment of the fitment issues because I was really hoping to get on the water Sunday. But, stuff happens and you don't always get to play when you want to. I'll survive. I am just hoping that it gets here before next weekend since we have a little Freeride in surfside that I am very much looking forward to. If it doesn't I could always rig up a 2 gallon red gas can...
I was going to lay up the reduction nozzle, but I'm exhausted. I'll knock that out tomorrow or Sunday.
I did receive the last of my packages for the next project I am working on. Whoever is the first one to correctly guess what I am making and identify all of the parts I will make a free coupler cover for. (except scraggly. No cheating Matt)
Id guess either an improved annodizing system or an improved heat cure system.
If you rig that setup with a red gas can, i will both applaud your inginuity and scorn your disrespect for what that machine desevers simultaneously.
