- Houston, TX
Picked up this square last week. It's definitely seen better days, but that was exactly what I was looking for.
The plan is to make the following changes, pull a mold, and build a lightweight ski.
Bottom Deck:
Rocker the nose
Reshape the center area of the rocker slightly (taper in the center line)
Custom Removable tubbies
Widen ski by 1-2"
Create full width ride plate
Shorten ~10". -6" out of the back and probably end up with -4" from the rocker/front
Widen pump intake track and pump area to accommodate a 155
Top Deck:
Slightly wider rails at 45*, transitioning to 90* towards the rear
Reshape nose
Move pole mounting forward
Lower and reshape hood
Reshape/lower gunwales
Widen tray
Front foot hold
Custom adjustable heated footholds
Carbon handle pole
Start
Current
Bottom Deck:
Rocker the nose
Widen ski by 1-2"
Top Deck:
Reshape nose
Widen tray
Front foot hold
Carbon handle pole
Start
Current
