Custom/Hybrid Matt_E's Superfreak Build
Huh ???
A what ???
Never mind.
How much padding will you use in the tray ? Them Florida boys don't believe in the cushy stuff but how else will you install the in-floor heating.
:lmao:
I personally don't like the 25mm stuff. I picked up two pieces of 8mm pad yesterday. I'll double that up in most of the tray (probably not in the middle).
Boris
The Good Old Days
OK,
Where's the chin pad in that drawing ?
How badly is that pole broken ??
Will you be visiting Key West next October with those graphics ???
Is it done yet ????
Some pictures from last night. I didn't do much. I tried fitting the pump. With only bolting up the front two, the shaft seems perfectly centered in the bulkhead hole.
The rear two mounts don't line up 100% with the pump, which is to be expected with a custom build I suppose. No big deal, I'll enlarge the holes in the mounting tabs.
Notice how wide the intake is and how the hull is a bit concave right before the intake.
Fitting the intake grate (Perfect fit!), plus a couple of stock length Superjet plates on there. Yah, it's short!
The battery tray. I was confused when I looked at it and had to call Tem/Nancy to figure it out. You just run a single strap looped underneath the plate.
Metal battery box for sale I suppose.
The carbon exhaust tube:
My Cold Fusion ebox mount.
