Got the cables routed in their final place. I integrated some cable clamps into two of the gas tank strap hooks and where the cables crossed under the midshaft, they were a little raised up and I didnt like how close they were to the coupler so I GFlexed a nut to the hull, and used two other cable clamps to be able to mount to one mount. I would have used another mini UFO mount, but I was out of them. It seemed to work out really will, and all the cables operate as smooth as normal. I gave myself a high five for that
I wrapped the steering cable in turf right behind the motor mount but it isnt pictured.
And then I spent like 25-30 minutes trying to get the dang hard line hose into the rear push to connect fittings all the way in the back hull and made a little tool out of a clothes hanger to help guide the line into place anddddd well........
Let this be a lesson for you guys...this hard line doesnt go into versi plugs very easily hahahahaha. I bent over a little farther in the hull, and realized the push connect fittings for the cooling line were much more accessible.
