BruceSki
Formerly Motoman25
- Long Island
So I didn't even ask. How did the wrist pin bearings look? How about the surface of the rods where the bearing rides?
All I'm saying is either water or a super rich condition is gonna wash the piston an domes. I'm by no means saying that's what happened, just a hunch. Water will instantly knock all carbon off a piston/dome. And those look awfully clean. The detonation signs is what throws a wrench into the mix. Good catch on finding it early tho.
Thrust washers still intact on the crank?
You may notice a difference in throttle response with 3 screens. I tried this at the beginning of this season before I toasted my motor.
Went from open style F/A (Prok) to two OEM 61X guys. It didn't run right until I pulled two screens out of it. Three screens is pretty restrictive compared to the open F/A or one screen and changes the carb signal. It dumps loads more fuel due to the low popoff pressure those carbs are set at.
Give it a shot though, but i have a feeling its not going to respond as well as it used to. W
you may need to adjust the carbs slightly. I went the easy way and went down to 1 screen. Although now I'm thinking about no screens.
I know, just saying 3 screens might make it load up and feel blubbery. Thats what happened to mine when I tried 3. Ran great when I dropped back to 1.
Sorry if I was unclear in the earlier posts.
Let me know how it works out for ya.
You'd need to raise the popoff.
