Modified X2 build (stripped the hull)
Vumad
Super Hero, with a cape!
St. Pete, FL
Well... i hadn't worked on the hull in 3 days... This is how the hull looked 3 days ago. I stripped all of the parts off of the hull. I stripped 95% of the gelcoat off. I didn't strip the gelcoat off the difficult areas because I may just be cutting those areas off anyway.
I did some work tonight... I pulled the remaining green stuff (not sure what it is) out of the pump area. The only remaining parts are the tube for the drive shaft and the 2 mounts for the intake grate. The mounts for the ride plate are messed up and will have to be replaced. The trim/steering tube are in the trash.
From here... I need to get with Tom from SkiShopRules.com and see what he has to say about the set up. I need to layout the hood, and the tray. The battery will end up under the seat. I'd like to get a 2-3 gallon fuel tank under the seat too. I'll probably have to custom make something out of glass and ISO resin. I also need to look at the fit of the factory 750 limited pipe in the hull, but since we're going riding tomorrow, I can't pull the 750 out of my SX to lay this out.
