Msd has a very poor timing curve.
Just an FYI.
The stock timing curve has more retarded built in so you can safely advance the timing more then with an msd.
But you need to know
6m6, 61x or 62t box.
Just an FYI.
The dotted yellow line is accurate for 6m6 cdi box.Tim, can you elaborate on this? I have always assumed this graph is accurate...
That heavy advance on msd before 1300 rpm is number one cause of start back fire as the unit doesn't always stay in start retard when crankingTim, can you elaborate on this? I have always assumed this graph is accurate...
I have always wandered why performance gain was so hit or miss with enhancers. I had a guy tell me just the other day the same thing TNT said about the enhancers. Non of his tested units had the same curve. I'm curious to see what OCD comes up with.
