You have to realize that the ignition system ramps up voltage until it creates enought volt to jump the spark gap. (I think ignition max voltage ratting is potiential volt).
You have to realize that MSD fires one plug a time (gap .029) and the Waste Spark System(OEM,ATP) fires both plugs together (gap .058). This means that the Waste Spark System needs to make more volts than the MSD to fire the plugs.
So when MSD went to dual channel, it would foul plug because the system made less volts, less heat to plug to burn off un burn fuel at idel and low rpms.
One reason why,IMO ,MSD went with dual channels and dual trigger coil was to offer a feature to retard the rear cylinder because of crank twist.
