- Lake Orion
New hood looks sweet
Sent from my iPad using Tapatalk
Well I wasn't going to make a "build" thread for two reasons
1: not sure it's a build being a new ski
2: I didn't think I'd be doing as much as I have to it this fast.
But I see others with 2014 builds and I figured what the hell it will be a good way for me to keep a record and look back on.
Bought my SJ on sept 4th around 6pm, and took it to the water and rode until sundown!
Took it out that weekend and rode all weekend burned through so many tanks. Hah. Broke my toe too.
Met up with some locals and rode for a little.
Then the mods began. I ordered a bilge bracket which I had trouble fitting but in the end bent it to work. Drilled my first hole in the side! Then one in the dashboard for the rotary switch.
I cut my ride plate down and also D cut it.
Put flame Arrestors on it at some point.
Did a pump cone
Blowsion finger throttle and UMI lock on grips
Other than that stuff that was it for a while.[/QUOTe
Can you provide information on cutting the skid plate? Length to be cut off, different riding experience etc.
Did a pump cone
Other than that stuff that was it for a while.[/QUOTE
Im not to sure what you mean about taking a pop can for a hole diameter, but I understand the cutting flush to hull. What is the use of the 2nd part?? Please clarify
What battery box is that?!
I thought I noticed it from Ebay! Would you recommend it?!?!?
