You have some mad skills and patience my friend.
What is that yellow stuff in that hood ?
Is it some plastic you shaped to use as a mold ??
I hope you have some more pictures of this thing coming up.
Thank you my friend ;-) More pics coming up next week. I have done the complete reinforcing on the inside (tray, engine bay, pole mount area), the hood is almost done and now I’m in the process of sealing all through hull components in the tray (scupper, water lines, my new exhaust outlet, etc.). I´m a little perfectionist, so it takes all longer than i thought, but i want it done right the first time.
That yellow stuff is duct tape for plastering. It comes in white and yellow. I found that the epoxy does not stick on it, so i use it as mould release agent. I build the mold out of thin pvc sheets (flat surfaces) and extruded foam pieces (air intake on the back of the hood) and then covered the entire mould in this plastering duct tape. Then i laid my glass/carbon/epoxy over it. After the epoxy has dried i can easily remove my composite part from the mould, peel the duct tape of and go on.
I also use this tape in my glass work sessions to produce even terminations to other components. I cover the abutting surfaces with this tape, glass over it and after the epoxy has dried i can carefully cut on the edge of the tape (through the laminate) and peel the excess of (together with the tape).
Hope, this is understandable ;-).
See post #3: picture 1, 4 and 5 and post #41: picture 2 and 3
