My budget freestyle build
jetskiking
Im done sanding!!!
Dallas Georgia
I had to take a break from sanding and fiberglass so I worked on the motor this week. Just need to torque everything and make a decision about what carb Im going to run.I painted the cylinders with metalcast I also painted the flywheel cover and the head pipe. Going to get started again on the bodywork as soon as I put some plastic up in the garage. I already have the plastic I've just been lazy. I need to get it done and get this over to my buddy's for paint.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
That metal cast ads some BLING.
ive got a very similar set up 650 superjet.
since that engine is apart, would you mind posting some more photos of the cylinders inside?
Id like to see some detailed photos of the protec bore job.
would it be possible ot measure the exhaust port? ( width, and height from the top of sleeve)
thanks!
jetskiking
Im done sanding!!!
Dallas Georgia
I can post some pictures of the cylinders with the head off but it is semi together. Im not going thru compressing the rings again:aargh4:The port job looks like they widened the ports about 3/16 of an inch. and the exhuast port is alot larger. At first I thought they just widened them but after compairing my stock 6m6 to this one they did raise it. Its bored to 81mm and the cases have been bored also to accept the larger bore.I was browsing through protecs website and it looks like somebody spent alot of money on this thing.The guy my buddy bought this motor from had it in a race boat from like 94 that looks like he never used, of course he did have two octanes.:bigeyes:
jetskiking
Im done sanding!!!
Dallas Georgia
Here are some pics. The first two are the 650 6m6 and the last two are the ported 701 6m6. You can somewhat tell in the pics how much bigger everything is, especially the exhuast ports. I cant remember what exhaust measurements were Ill try to get those for you next time I have the mic here.It will be about a week before I bolt the head on. Im still waiting for gaskets from protec
jetskiking
Im done sanding!!!
Dallas Georgia
So Ive been taking a break from the grindstone!!! I put my nose back to it and started finishing up some odds and ends before I paint. Im wrapping up my hood mod. Done glassing in the vents and made handholds. Im glassing in the liner tonight. Ive just got to Finish sanding:banghead:
jetskiking
Im done sanding!!!
Dallas Georgia
Now its starting to come together:Banane01: Im done in my engine bay. I just have the motor sitting there. Im done with the hood other than after paint stuff and im going to drill tubes after motor is installed.I made my liner so every bolt hole is acccessible. I've Hit the whole body including the bottom with 100 grit , Still need to sand on hood some more then block everything out up to 320 and prime,Paint and final assembly.Sorry just running through checklist. May still be a few goodies added during final assembly:sneaky: Any how heres some more pics.
douglee25
m3booooy
South Jersey
You should paint your head gray to match the rest of the block. That would look madd sweet!:woot:
Doug
jetskiking
Im done sanding!!!
Dallas Georgia
2lick said:
what did you use as a liner???
I just used frp from home depot then layed a layer of fiberglass on that. Ive got everything sanded to 320 except the bottom and the nose piece I just got from royalflush. Ive been doing a little filling on the bottom. Not going to spend much time on the bottom cause it will just get trashed but wanted to fill in any deep gouges. I just used epoxy with silica and put a very light skim coat then sanded it back off. Starting to Primer tomorrow:arms: Then I'll wetsand the primer with 400 and paint. I'm Sending my carb to Jetworks monday for Blackjack mod. I also lack a couple odds and ends like bow eyelets and bilge fittings but I'll pick those up next week.
jetskiking
Im done sanding!!!
Dallas Georgia
2nd nature said:
lets see it.
Alright, I got the color on today:biggrin: Its actually Darker in person. More the color of a blue plastic party cup. Also has green pearl in it. I got some fish eyes on the nose cover but will correct it. So when we doing yours Nature?
jetskiking
Im done sanding!!!
Dallas Georgia
Heres some more pics. I got to see it today in the sun.The pearl looks crazy:cool2: . Now its time to assemble. Im not sure why the blue looks so light in the pics? Cant wait till I get to ride it this weekend :woot: Im thinking red fuel line?
jetskiking
Im done sanding!!!
Dallas Georgia
O.k. Motor is installed, handle pole is on, controls are pulled,Bilge pump and bracket installed with wiring,Waterbox is in. Waiting on my O.D.I grips and billet fittings from blowsion. Im installing the turf tomorrow. Im turfing the front of the tray. Should I install electric box bolts through the turf, should I turf over them or should I cut holes around them? Im also still undecided about If I want to install the bumpers and turf all the way to the side or leave them off and just turf the area they cover on the rails. Any sugestions?
jetskiking
Im done sanding!!!
Dallas Georgia
Jacob06 wanted me to post turf pics so here they are. Oh yeah and Im basically done. Just gotta flip hood hardware and wait on 5200 to dry. Im going to paint the inside of hood black after Lanier.They sides and foothold are one piece molded with heatgun and theres a 1/2 inch pad on the bottom.
jetskiking
Im done sanding!!!
Dallas Georgia
Heres the rest Of the pics and what I ended up with.Now my old reliable back up boat is built. Now its time for a round nose and a big nasty unreliable motor:biggrin:
  1. Protec ported 6m6 bored to 701
  2. Protec 175 Psi head
  3. boysen reeds
  4. coffmans pipe
  5. 701 ignition (soon to be msd)
  6. mikuni 44(soon to be blackjack)
  7. 12oz biax reinforcment on bottom and handlepole area
  8. 12oz biax and plainweave carbon(4.7oz I think) on sides
  9. Cyclone footholds
  10. Hydroturf with 1/2 pad
  11. Slutty hood mod with handholds
  12. Ocean pro open ocean ride plate
  13. Riva intake grate
  14. Solas prop
  15. wetwolf cone
  16. hood straps
  17. Umi bars with crossbar
  18. O.D.I grips
