Just took a quick look at your pics. You have a 62t flywheel with a 61x stator. That is an issue and why your expected charge coil resistance is out of spec.
Also those are VForce 1 reeds and cages so that is a bonus, but you should remove the reed spacer for freestyle use. It increases the effective case volume which lowers low end hit.
