Super Jet My First RN Build - Complete rebuild, shorten, and rocker!
Also spent a good hour getting a broken bolt out of the intake on the top case..
Gonna have to get a threaded insert or a m8 to m6 stud but I got it out thank god. Also pulled the other 3 studs too, rather one break now then later.
This is how a ski should be redone!! Good stuff man!
Thanks MADMAT! Tonight I'll be blasting the flywheel cover, cylinder, head, and cleaning all my hardware to see if I need to order any new stainless from McMaster Carr.
Later this week I will be placing my order with @JetManiac for an SBT crank, 83mm Pro-X pistons, and a few other goodies :) Can't wait....
Also in the works is getting my cases fixed, have a crack where the Mag side crank bearing pushed the alignment pin through into the flywheel area. Need to push that pin back out and weld the inside of the flywheel area. Also one of my flywheel cover mounting holes on the upper case is cracked which will be repaired. No shortage of work to do :)
OHHH LOL! Tim Lagow. Avoid at all costs. To make matters worse... that starter he said was gonna buy... you can imagine my reaction when I opened the package to find a $40 eBay Caltric starter, should make quite the nice paperweight or doorstop. On the plus side the stator he sent is OEM and works good. Too bad the starter was a metaphorical slap in the face.
Question: Powder coat cylinder then send to GroupK for hone and bore? Or vice versa?
