Super Jet My First RN Build - Complete rebuild, shorten, and rocker!
I already placed a huge order with Jetmaniac which includes 83mm Pro-x pistons but I really didn't want to drop the $500+ for a ported kit, I'm sure its an amazing value but I'm already burning holes in my pockets with this build lol.
So today I made some decent progress. I cleaned my carbs and they are ready for paint and rebuild. I also got my cylinder head, flywheel cover, FP manifold, and some more of the cylinder cleaned, taped and blasted.
IMAG0578.jpg IMAG0580.jpg IMAG0585.jpg IMAG0586.jpg IMAG0582.jpg IMAG0583.jpg IMAG0589.jpg IMAG0590.jpg
Why arent you blasting the inside of bpipe manifold?
Once i get my gaskets, I plan on matching all my ports to the manifolds and gaskets, so I didn't see the point right now. Plus ive read into porting a lot and seems the going concensus for best flow is rough surface on the intake side and smooth on the exhuast.
Been quite a while since i posted last. Havent gotten a whole lot done. Been mostly prepping for powder coat and started soda blasting my carbs. This week should be more productive :)
So ill admit i didnt choose the nicest day here in Minnesota (-5F) to go out into an unheated shop and pull my pump assembly. What should have been a simple twenty minute job turned into two toe and face freezing hours that ended with me tying a rope around my pump, the other end to my trailer, and proceeding to slide my ski forward at mach 2 to yank out my insanely seized driveshaft....
So ive determined my bearings in the pump and midshaft are great, finally some good news... and the impeller looks new :) i believe its from an 08 superjet?? It has 6BA stamped on the side.
Still havent started hull mods unfortunately, however i did start porting my cases. I started with doing gasket matching and did a little intake porting. Still lots to go as i was taking it easy. Something inherently creepy about taking chunks out of your crankcases for the first time lol.
MN
where are you in MN? there are good shops around to have some routine machine work done
