got the pump and ride plate in. had to grind down the rideplate some to get it to fit, and it hits the pump a little so i had to adjust that a little bit. also had to cut off the spot where the original steering cable mounts to on the pump and move it in because the original spot hits the rideplate. also got the motor test fit in and everything seems to line up good, just gotta get my exhaust so i can figure out what im doing with that, and get my pole bracket so i can get that mounted up
