- Long Beach, CA
I put my sxr on a diet too. Try slicing up the engine plate a bit, i cut the center out, that probably dropped 2lbs. anything that looks like stainless steel............toss it, i tossed every stainless bracket except the one holding the electrical but i cut holes all over that, cut the bottom of the battery tray out, you can go with a 5lbs battery if you don't have total loss, TBM flywheel is -3lbs, gut the hood like kv454, go hydro turf, stock rails are heavy, D-cut the ride plate, you can also remove the rear exhuast and route it out up front that saves 9lbs from what I hear, tossed the stock bilge,nomore reserve switch & hoses, toss the stock air box and more.
