- Cleveland Ohio
That's what I did...still not on the water though....soon!
Don't think Art is only Yamaha, he owns an SXR powered X2, he knows Kawasaki as well.
Here's my new setup: Blackjack Performance 84mm (820cc), ported cylinder, JSU (Kommander) head for pump gas, Jetworks programmed Advent T3, Blackjack 40mm I bodies (he refuses to Blackjack SXR carbs anymore, he swears by doing a thin tube atomizer instead), V-Force 3 reeds with spacer, RAD charging flywheel, and Power Factor pipe. Pump is stock with 650 reduction/steering nozzle and Solas 14/22 impeller (came on ski, planning on changing once I figure out what I might need, however I'd like a Solas 'mag', and love a larger Skat).
I have some taper bore 44 carbs I plan on swapping to, then probably eventually getting them Blackjacked.
Cannibal, How much difference did you feel with the porting?
PFP?
