- Glenmoore pa
Idk if I said this before but I’m not really trying to compete with zeel. It’s a great plug and play setup. This is more advanced and targeted for people who want more control and more precision.
How will you mark the flywheel with the flywheel cover on? How I would think to do this is maybe index off of the 3 bolt hole for pulling the flywheel, unless they are just in random spots.I’m going to include a pin that you put in the sensor hole and seats into the missing tooth. Set motor at TDC, put pin in place. Mark and drill a small hole in snout of crank and tap in a roll pin. I’d call that optional but keeps you from having to reset every time u remove flywheel. This will get u in the ballpark. Verify with timing light and adjust static angle as needed. It’s nowhere near as plug and play as zeel, but it’s tough to solve. I’ve got some ideas to simplify the setup in the future.
You won’t. Put the cover on just with a bolt or two, slide alignment pin in, take cover offHow will you mark the flywheel with the flywheel cover on? How I would think to do this is maybe index off of the 3 bolt hole for pulling the flywheel, unless they are just in random spots.
Yes, agreed. I just need a simple way for people to get the wheel in pretty close ballpark during initial setup.TDC can and should ALWAYS be confirmed with a simple piston stop.
Don't worry you are not the only one not getting thisI'm a little slow I guess, I'm having a hard time picturing how the trigger wheel attaches. Just clamps under the flywheel bolt up against the flywheel? Then what part of the crank are you drilling and putting a roll pin into/through? Isn't the crank end completely covered by the flywheel?
you would be pinning it into the flywheel not into the crank.I'm a little slow I guess, I'm having a hard time picturing how the trigger wheel attaches. Just clamps under the flywheel bolt up against the flywheel? Then what part of the crank are you drilling and putting a roll pin into/through? Isn't the crank end completely covered by the flywheel?
This is an earlier version but u get the idea. The pin goes right behind the bolt where I circled in red. It’s not even really necessary. If you are ok using a timing light, yes the cover never needs to come on and off. Just need to mark TDC somewhere so you can verify timing and adjust with static angle setting.I'm a little slow I guess, I'm having a hard time picturing how the trigger wheel attaches. Just clamps under the flywheel bolt up against the flywheel? Then what part of the crank are you drilling and putting a roll pin into/through? Isn't the crank end completely covered by the flywheel?
Exactly.you would be pinning it into the flywheel not into the crank.
What made you switch to the lower tooth count?This is an earlier version but u get the idea. The pin goes right behind the bolt where I circled in red. It’s not even really necessary. If you are ok using a timing light, yes the cover never needs to come on and off. Just need to mark TDC somewhere so you can verify timing and adjust with static angle setting.
Spacing was too tight for a hall sensor.What made you switch to the lower tooth count?
Not enough resolution for accuracy between pickup points.Why not do the trigger of 3 pickups coils? 2 for triggering like the tl/zeel and the 3rd for sync?, then it doesnt need a trigger wheel? Wich equals to less rotating mass on the crank?
That’s the exact problem I’m trying to solve. I theorize there’s not enough resolution with zeel/etc to be accurate on these stroker motors with fast crank speed fluctuations.Why not? Have you tried?
I know alot of high end stand alone systems that use 2 tooth + sync as trigger and it works great
This little wheel is not adding much rotating mass. I’ll try to weight it for you this weekend. Plus u can chop the front off a lightened 760 flywheel if you want the lightest flywheel ever. People generally incorrectly think a super light flywheel is the best choice for performance anyway.Then thats a problem to solve then I guess, idont think anyone wants some additonal weight to the crank
