So do you plan on having a pipe for every hull? That would be alot of different models.good luck on whatever design you settle on and manifold you come up with,I would really like to try one and would be able to test it with a few powerplants.
Sent from my SCH-I605 using Tapatalk 2
Ride no I will only make the different tune dimensions.
The 3 designs right now will get renamed as they get tested by multiple people with different setups.
The homo mod II pipe in three different boats seems to be king in spec boat. So that most likely will become spec pipe.
The CC pipe like one Ralph has is performing best in 800cc plus boats and to soft on bottom and mid for spec so it's most likely to stay the prototype name mod chamber
The free ride pipe is way behind in testing and what I thought would be first pipe into production is going to be by far the last. As this pipe needs to be totally redesigned to fit all the aftermarket hulls and will turn into winter project.
The exh manifolds will be available next yr.
Wax head, do some measuring for me.
With telescope magnet or mirror extend it in hull on pipe side tape it so it stands straight up and close latch hood, take good off and measure length of it, that give me your to good measurement, measure from cyl exh Gasketet surface to hood seal flange or the narrowest part of hull.
From hack of cyl to hood seal lip.
It's possible to dent the pipe in those areas up to inch deep and make fit.
It won't be very pretty but may fit. The dents have to be smooth and rounded or performance can suffer.
The freeride hulls are much tighter in those areas so that be the pipe most likely to fit.
But won't be available till next yr.
ok guys I have to get back to work, will be slow to respond for next week as most my Mx kids be back from lorretta Lynn this week and all there bikes need to get prepped for mini O's.
Ps, I will likely be in Florida for mini O's and will bring few pipes with me and have one day to test watercraft after race.
So if your in Florida have R&D manifold want to test this would be your chance to try new tnt pipe without any investment.
