Christian_83
Xscream
- Denmark
Your welcome, hit me up with a pm if i can be at any help
Nice man. Same box I use. Nema4 x never leaked. It's redundant to build a dry box and leave the high voltage coils out of it. I set mine up lil diff inside. Pics are posted here couple years back.@IceMan
My MSD TL also has around 3 years to it, only around 50 hours though.
But my setup never missed a beat, even though i mainly ride salt.
A tip for everyone is to let NO of the original wires from the MSD brain out in the hull, were they are exposed to salt water and salt "vapor"
I made a commen positive 12v+ on the starter relay, that my red and violet connects to (hard wired) Same for ground, i got 2 grounds.
But once a wired is exposed to salt water it goes extremely fast with degrading it. Ask me how i know (I'm a electrician, and the past 5 years i worked offshore)
Who is marketing that. it looks like an igniproNice man. Same box I use. Nema4 x never leaked. It's redundant to build a dry box and leave the high voltage coils out of it. I set mine up lil diff inside. Pics are posted here couple years back.
Ice. That's the box you want for msd tl The coils shorted and shocked You last time. My msd brain is 6 yrs old 3 in this box. But this is the ign u will want for less hassle and better programmable curves for new pipes and port timing . Fits oem box 10 x better quality connectors. Super accurate. No need for multi spark and ultra high amp discharge to increase likely hood of complete ignition and perfect timing. Less than 10 amps instead of the msd 30 amp. Lith batt will run 3 x more tanks fuel with it than msd tl. Fw is lighter than msd. Cost from what I'm told is significantly less than msd. Win win. But what do I know
What's the price range on it?We are working on our new ignition system for some time now, a month or so and a few dozens of dyno runs, it should be available. Own designed flywheel, stator plate and software
Sent from my HTC One_M8 using Tapatalk
We are working on our new ignition system for some time now, a month or so and a few dozens of dyno runs, it should be available. Own designed flywheel, pickup system, stator plate and software
I knowDon't you know that dyno numbers don't count on pwc.
Please wait a little bit longer all the information will be released soon.What is included ? How is it programet ?
