New Superfreak Badass hull Test ride
Fl
Yes you can run a stock tank and water box with a B pipe but Lucas is running the PFP so it's a 3 gal Jazz tank in the test ski .
FlightPlanDan
Don'tTrustAfartAfter50
I keep looking at it.....and looking at it..... I understand why Lucas is in love, and I've not seen it in person. The graphics are perfect as well. A statement, but not over the edge. If I had one of those, I would not put any decals on it.
However, things as they are, I'll likely be one of the bottom-feeders that harvest the leftovers from the previous projects of new superfreak owners! (we all have a purpose!)
LOVE THAT HULL!
AlbanyMotorsports
Cru is Rad
Chicago
that was an xs1000 with a 145 mag. mine will be a -3 with a powervalve polaris motor i've been working on. will start with a 140 mag and depending on how much power my ski makes i may move up to 148. but here's me after about 10 minutes of riding and i haven't been on a ski in atleast two months. first attempt. this was no trim and me not yanking.
yes i'm 260lbs :(
If you are building a Pol motor with anything over 800cc you will be one happy camper with it in that small hull. They are mules. Nice to see someone else building one.
JetManiac
Stoked
Vendor Account
orlando
What nose comes with the ski regularly? Does it have a bond line around the front? Love to hear some feedback on how it handles in the surf
The nose will have a continuous bondline around the front that follows the nose rocker upswept in the front. Tem is mainly a surf rider. These hulls have many changes designed with the surf in mind. Tem is building one for himself and one for me right now, we will be ripping surf with them fairly soon. Hopefully Josh(aircraftsalz) will take his out in the surf before changing his pipe to powerfactor flatwater use.
awsome hull Tem,you really are taking it to the next level with this one. whats the deal with the super short pole? are the surf setups going to use that same length,Do you use the same type foothold in your surfboat as well?
Aircraftsalz
Thrust built Dasa Power
Off site
The Short pole is for flatwater, it feels perfect when your riding, no back pain at all. The footholds are very nice with a lot of padding. When your locked in your in.....
Mine will be in the surf with either pipe!!!! But only on small days, I'm going to be at the lake most of the time now unless the surf is perfect..
No integrated front foothold anymore?
You can still have it, I'm not going to have one. Just a strap for surf stance FW flips....
