BrightE's
Paul
- Seattle, WA
I'm starting this new thread just for getting help with my ski, cause the threads I posted in are getting off topic with my ski running issue. I recently installed a used MSD 2530 TL system on my otherwise stock 701, the whole system came out of a running Superjet that had an MSD Enhancer. The TL was wired running on channel 1 and channel 2 (Yellow and brown off the brain) so I kept it that way. Both carbs are in sync with each other.
When I pull the plugs and place them on the head and turn over, I get great, healthy sparks on both plugs.
Here is what is happening:
1. The ski starts fine out of the water, though when put in the water it is hesitating very badly even at full throttle it just putters along until the engine can (if it can) get up to this mid-range RPM range. Edit: Now having trouble even starting.
2. At this point the ski jolts into good power (no matter if it happens at full WOT throttle, or if I am letting it off), and can maintain it if I don't give up on the throttle at all, but it's hard cause it's all or nothing.
3. I pulled the plugs (both brand new) and only the rear plug is getting color (good light brown color). The front plug still looks brand new.
4. I pulled the carbs, flushed them, put a new gasket under them and reinstalled them.
Edit - Ski Setup:
*701, unported, 35cc ADA domes
*Solas Mag pump (it was a little difficult to spin after I had my drive shaft installed, but seems better now), 9/15 Hooker
*B-Pipe, stock waterbox, top screw is the only one that is open. The middle and bottom screws are closed (for bottom end power only).
Carb Settings:
Main Jet: 135
Pilot Jet: 70
High speed screw: 5/8 turns out from closed
Low speed screw: 1 and 3/8 turns out form closed
Needle & Seat: stock (55 psi)
Spring: Stock (95 gram)
TL Settings:
Static Timing: 31
Max Timing (-2): 29
Max RPM: 8250
Begin Retard: 5000
Max Speed Retard: 17
Here are the actual dips:
My best guess is that I am running only on one cylinder until it gets up to some X RPM, at which point they both go on. It's weird, I don't know what to do! Help!
Edit - Ski Setup:
Carb Settings:
Main Jet: 135
Pilot Jet: 70
TL Settings:
Static Timing: 31
Max Timing (-2): 29
Max RPM: 8250
Begin Retard: 5000
